20 years ago
The DIR "romfs" must be created??
I have done "make"and "make linux image"
BUT,
[root@localhost uClinux-dist-test]# make
make -C tools/ucfront
make[1]: Entering directory `/home/ziguowei/uClinux-dist-test/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/ziguowei/uClinux-dist-test/tools/ucfront'
ln -sf /home/ziguowei/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/ziguowei/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/ziguowei/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-l
d
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_CO
MPILE=nios2-linux-uclibc- -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/ziguowei/uClinux-dist-test/linux-2.6.x'
CHK include/nios2_system.h
CHK include/linux/version.h
CHK include/linux/compile.h
CHK usr/initramfs_list
/home/ziguowei/uClinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: Ca
nnot open '/root/uClinux-dist-test/romfs'
make[2]: *** [usr/initramfs_list] Error 1
make[1]: *** [usr] Error 2
make[1]: Leaving directory `/home/ziguowei/uClinux-dist-test/linux-2.6.x'
make: *** [linux] Error 1
[root@localhost uClinux-dist-test]# make linux image
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C
/home/ziguowei/uClinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open '/root/uClinux-dist-test/romfs'
Pls give me some advice.
Thanks!!
    do "make romfs" first, it will fail but the romfs dir is created.
    I 'm new to uClinux, I try to follow
    Wiki UClinuxDist and have the same error,
    make[1]: Entering directory `/home/fischer/work/nios/uClinux-dist-test/tools/ucfront'
    make[1]: Für das Ziel »all« ist nichts zu tun.
    make[1]: Leaving directory `/home/fischer/work/nios/uClinux-dist-test/tools/ucfront'
    ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
    ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
    ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
    make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x zImage || exit 1
    make[1]: Entering directory `/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x'
    perl -I/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < ../std_1c20.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    /home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open &#39;/home/fischer/uClinux-dist-test/romfs&#39;
    make[2]: *** [usr/initramfs_list] Fehler 1
    make[1]: *** [usr] Fehler 2
    make[1]: Leaving directory `/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x&#39;
    make: *** [linux] Fehler 1
    however I run make romfs and directory romfs exists in directory uClinux-dist-test
    with the following content:
    insgesamt 0
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 bin
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 dev
    drwxr-xr-x 4 fischer users 248 2006-07-30 14:10 etc
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 home
    lrwxrwxrwx 1 fischer users 9 2006-07-30 14:10 init -> /bin/init
    drwxr-xr-x 2 fischer users 80 2006-07-30 14:10 lib
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 mnt
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 proc
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 sys
    lrwxrwxrwx 1 fischer users 8 2006-07-30 14:10 tmp -> /var/tmp
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 usr
    drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 var
    thanks
    --- Quote Start ---
    originally posted by fischer@Jul 31 2006, 05:31 AM
    i &#39;m new to uclinux, i try to follow
    wiki uclinuxdist and have the same error,
    make -c tools/ucfront
    make[1]: entering directory `/home/fischer/work/nios/uclinux-dist-test/tools/ucfront&#39;
    make[1]: fã¼r das ziel â»allâ« ist nichts zu tun.
    make[1]: leaving directory `/home/fischer/work/nios/uclinux-dist-test/tools/ucfront&#39;
    ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
    ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
    ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
    make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x zimage || exit 1
    make[1]: entering directory `/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x&#39;
    chk include/nios2_system.h
    perl -i/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < ../std_1c20.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; upd include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    chk include/linux/version.h
    chk include/linux/compile.h
    chk usr/initramfs_list
    /home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: cannot open &#39;/home/fischer/uclinux-dist-test/romfs&#39;
    make[2]: *** [usr/initramfs_list] fehler 1
    make[1]: *** [usr] fehler 2
    make[1]: leaving directory `/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x&#39;
    make: *** [linux] fehler 1
    however i run make romfs and directory romfs exists in directory uclinux-dist-test
    insgesamt 0
    thanks
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17267)
    --- quote end ---
    --- Quote End ---
    I did mention to make romfs after hwselect,
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    make linux_hwselect SYSPTF=~/your_project/your_system.ptf
    make romfs# to create romfs dir, make will fail, ignored
    Then config uClinux-dist for costmize kernel.
    make menuconfig[/b]
    --- Quote End ---
    Hi Hippo,
    I got the same thing. I did all that was on the wiki, but still get this.
    uclinux@colinux:~/download/uClinux-dist-test$ make
    make[1]: Entering directory `/home/uclinux/download/uClinux-dist-test/tools/ucfront&#39;
    make[1]: Nothing to be done for `all&#39;.
    make[1]: Leaving directory `/home/uclinux/download/uClinux-dist-test/tools/ucfront&#39;
    ln -sf /home/uclinux/download/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
    ln -sf /home/uclinux/download/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
    ln -sf /home/uclinux/download/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
    make[1]: Entering directory `/home/uclinux/download/uClinux-dist-test/linux-2.6.x&#39;
    perl -I/home/uclinux/download/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/uclinux/download/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu ddr_sdram ext_flash < std_2C35.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
    /home/uclinux/download/uClinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open &#39;/home/uclinux/uClinux-dist-test/romfs&#39;
    make[1]: Leaving directory `/home/uclinux/download/uClinux-dist-test/linux-2.6.x&#39;
    Please help.
    Al
    hello albertyong88
    your directory is: /home/uclinux/download/uclinux-dist-test
    but it trys to find romfs under : /home/uclinux/uClinux-dist-test
    i had the same error until i moved uClinux-dist-test directly under my home
    directory: in your case it should be /home/uclinux/uClinux-dist-test
    Hi Fischer,
    Thanks for the the tip. I will try it when i get to work tomorrow.
    --- Quote Start ---
    originally posted by fischer@Aug 11 2006, 11:27 AM
    hello albertyong88
    but it trys to find romfs under : /home/uclinux/uclinux-dist-test
    i had the same error until i moved uclinux-dist-test directly under my home
    directory: in your case it should be /home/uclinux/uclinux-dist-test
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17549)
    --- quote end ---
    --- Quote End ---
    Hi Fischer,
    It works !! Thanks. You rock.
    --- Quote Start ---
    originally posted by albertyong88+aug 13 2006, 05:16 am--><div class='quotetop'>quote (albertyong88 @ aug 13 2006, 05:16 am)</div>
    --- quote start ---
    hi fischer,
    thanks for the the tip. i will try it when i get to work tomorrow.
    <!--quotebegin-fischer@Aug 11 2006, 11:27 AM
    hello albertyong88
    --- quote end ---
    --- Quote End ---
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17558)</div>
    [/b]
    --- Quote End ---
