20 years agoThe DIR "romfs" must be created??
Hi, I have done "make"and "make linux image" BUT, [root@localhost uClinux-dist-test]# make make -C tools/ucfront make[1]: Entering directory `/home/ziguowei/uClinux-dist-test/tools/ucfr...
20 years agoHi Fischer,
It works !! Thanks. You rock. --- Quote Start --- originally posted by albertyong88+aug 13 2006, 05:16 am--><div class='quotetop'>quote (albertyong88 @ aug 13 2006, 05:16 am)</div>--- quote start ---
hi fischer,
thanks for the the tip. i will try it when i get to work tomorrow.
<!--quotebegin-fischer@Aug 11 2006, 11:27 AM hello albertyong88
your directory is: /home/uclinux/download/uclinux-dist-test
but it trys to find romfs under : /home/uclinux/uclinux-dist-test
i had the same error until i moved uclinux-dist-test directly under my home
directory: in your case it should be /home/uclinux/uclinux-dist-test
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17549)
--- quote end ---
--- Quote End --- <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17558)</div> [/b] --- Quote End ---
