20 years agoThe DIR "romfs" must be created??
Hi, I have done "make"and "make linux image" BUT, [root@localhost uClinux-dist-test]# make make -C tools/ucfront make[1]: Entering directory `/home/ziguowei/uClinux-dist-test/tools/ucfr...
20 years ago --- Quote Start --- originally posted by fischer@Jul 31 2006, 05:31 AM i 'm new to uclinux, i try to follow
wiki uclinuxdist and have the same error,
make -c tools/ucfront
make[1]: entering directory `/home/fischer/work/nios/uclinux-dist-test/tools/ucfront'
make[1]: fã¼r das ziel â»allâ« ist nichts zu tun.
make[1]: leaving directory `/home/fischer/work/nios/uclinux-dist-test/tools/ucfront'
ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/fischer/work/nios/uclinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld
make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x zimage || exit 1
no emulation specific options.
make[1]: entering directory `/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x'
chk include/nios2_system.h
perl -i/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < ../std_1c20.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' upd include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
chk include/linux/version.h
chk include/linux/compile.h
chk usr/initramfs_list
/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: cannot open '/home/fischer/uclinux-dist-test/romfs'
make[2]: *** [usr/initramfs_list] fehler 1
make[1]: *** [usr] fehler 2
make[1]: leaving directory `/home/fischer/work/nios/uclinux-dist-test/linux-2.6.x'
make: *** [linux] fehler 1
however i run make romfs and directory romfs exists in directory uclinux-dist-test
with the following content:
insgesamt 0
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 bin
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 dev
drwxr-xr-x 4 fischer users 248 2006-07-30 14:10 etc
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 home
lrwxrwxrwx 1 fischer users 9 2006-07-30 14:10 init -> /bin/init
drwxr-xr-x 2 fischer users 80 2006-07-30 14:10 lib
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 mnt
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 proc
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 sys
lrwxrwxrwx 1 fischer users 8 2006-07-30 14:10 tmp -> /var/tmp
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 usr
drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 var
thanks
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17267)
--- quote end ---
--- Quote End --- I did mention to make romfs after hwselect, <div class='quotetop'>QUOTE </div> --- Quote Start --- make linux_hwselect SYSPTF=~/your_project/your_system.ptf make romfs# to create romfs dir, make will fail, ignored Then config uClinux-dist for costmize kernel. make menuconfig[/b] --- Quote End ---
