20 years agoThe DIR "romfs" must be created??
Hi, I have done "make"and "make linux image" BUT, [root@localhost uClinux-dist-test]# make make -C tools/ucfront make[1]: Entering directory `/home/ziguowei/uClinux-dist-test/tools/ucfr...
20 years agoI 'm new to uClinux, I try to follow
Wiki UClinuxDist and have the same error, make -C tools/ucfront make[1]: Entering directory `/home/fischer/work/nios/uClinux-dist-test/tools/ucfront' make[1]: Für das Ziel »all« ist nichts zu tun. make[1]: Leaving directory `/home/fischer/work/nios/uClinux-dist-test/tools/ucfront' ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-gcc ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront tools/ucfront-g++ ln -sf /home/fischer/work/nios/uClinux-dist-test/tools/ucfront/ucfront-ld tools/ucfront-ld make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x zImage || exit 1 no emulation specific options. make[1]: Entering directory `/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x' CHK include/nios2_system.h perl -I/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts /home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl cpu sdram ext_flash < ../std_1c20.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo ' UPD include/nios2_system.h'; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi CHK include/linux/version.h CHK include/linux/compile.h CHK usr/initramfs_list /home/fischer/work/nios/uClinux-dist-test/linux-2.6.x/scripts/gen_initramfs_list.sh: Cannot open '/home/fischer/uClinux-dist-test/romfs' make[2]: *** [usr/initramfs_list] Fehler 1 make[1]: *** [usr] Fehler 2 make[1]: Leaving directory `/home/fischer/work/nios/uClinux-dist-test/linux-2.6.x' make: *** [linux] Fehler 1 however I run make romfs and directory romfs exists in directory uClinux-dist-test with the following content: insgesamt 0 drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 bin drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 dev drwxr-xr-x 4 fischer users 248 2006-07-30 14:10 etc drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 home lrwxrwxrwx 1 fischer users 9 2006-07-30 14:10 init -> /bin/init drwxr-xr-x 2 fischer users 80 2006-07-30 14:10 lib drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 mnt drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 proc drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 sys lrwxrwxrwx 1 fischer users 8 2006-07-30 14:10 tmp -> /var/tmp drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 usr drwxr-xr-x 2 fischer users 48 2006-07-30 14:10 var thanks
