16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it probably applies to all devices. Once programmed by the flash programmer(SP2) the cyclone II won't boot on power up anymore.
Programming the sof through JTAG will work and NIOS will self boot. Programming a JIC file will also work, but of course NIOS isn't there to boot. I completely uninstalled Quartus and NIOS and reinstalled everything back to SP1 and it all works again just as it should. Users be warned! Dan
