16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agoThe first one is the standard web edition package. It has a bug when run on FAT32 partition though, so if you want to install it on FAT32, you should download the second one instead.
