16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agoAnother sample point...I thought I'd try using the flash programmer in my system to see if I had the same problems. I'm running Quartus and NIOS SBT (not the legacy IDE) at rev level 9.1 sp2. My system contains Cyclone-III (EP3C40) and an EPCS16. I left the "Generate compressed bitstreams" option enabled in Assignments->Device->Device and Pin Options->Configuration. Everything works fine...NIOS boots and runs as desired.
