16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agotyekuhn, the problem occurs with StartixII when using the sof2flash utility. Altera was requested regarding that issue under SR10756943. I'll tell you if I have an answer.
Jens
