Problem booting program from EPCS flash and running from SRAM
Hardware and software tools:
NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.The problem as described in the title keeps popping up frequently in this forum so it might be a good idea to post the solution (step by step) in "Sticky" messages.Anyhow,i am facing the following problem - I have the FPGA and software tools and i also possess EPCS128 flash and 8 MB SRAM.I want to boot the Nios II program from EPCS and run in 8 MB SRAM.At this point i am able to run the program only in debug mode.In order to solve the issue I have tried the following solutions: http://alteraforums.net/forum/showthread.php?t=20623 --->I have reached the point when i created the joint (concatinated) hw+sw bin file and i have no idea what to do next (I saw that this is impossible to burn that file to flash using the console programmer ,maybe some conversion is required?) http://www.altera.com/support/kdb/solutions/rd12092009_471.html -->Trying to create .jic file and then burn that file using Quartus programmer.I have succeeded in doing this ,but the program still won't run after power-off and power-on,meaning it has not been programmed properly.Maybe the problem lies in the fact that the *.elf file used was from "Debug" directory and not "Release" (For some reason,the option of 'Release' has disappeared from IDE and i am not able to find that option anywhere). Any help would be appresciated Thank You very much, Michael18 Replies
Anybody has an answer?
The "app_image.bin" file generated on the first link you give is the very exactly image of the data flash.
you can try this, it could work :
and then program it with serial flash loader... [edit] I remove what I have write about the second link... it was wrong :oops:nios2-elf-objcopy -I binary -O ihex app_image.bin app_image.hex - Altera_Forum
Which boot loader are you trying to use?
Here is the script I use to load up an EPCS with a FW/SW pair. The <EPCS BASE> should be the hex address of your EPCS controller component in SOPC Builder. (i.e. 0x04020000) Let me know if this helps. (as I can't send you a private message yet - too few posts:mad:)
#generate flash image for firmware <fw1> "$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="<fw1>.sof" --output="<fw1>.flash" # program <fw1> firmware into flash memory "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=<EPCS BASE> --cable='USB-Blaster ' --instance=0 "<fw1>.flash" # generate flash image for <fw1> software <sw1> "$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="<fw1>.flash" --input="<sw1>" --output="<sw1>.flash" # program <sw2> into flash memory "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=<EPCS BASE> --cable='USB-Blaster ' --instance=0 "<sw1>.flash" - Altera_Forum
i have tried this method already(and the gui flash programmer method,which is almost identical),still without success.I guess the problem is either in sopc builder configuration or in the board itself
In SOPC, what are your reset and exception vectors in the NIOS pointing to?
My NIOS values are set to: Reset - EPCS Controller Exception - External RAM (I am assuming you have an EPCS controller block in your sopc project, it is required (normally) for the processor to boot from the EPCS) - Altera_Forum
yes,i have checked about thousand times.
Now i have set up an internal small RAM inside the fpga-the program boots from epcs and runs inside the on-chip RAM,so i guess the problem is in the access to external RAM - Altera_Forum
I have the same problem. If I link my program to the SRAM, it doesn't boot, but if I link to the Onchip_memory, without change any other parameter or the script, it boots!
I've checked what is written in the SRAM after boot, and it's not the right code, I don't no why! At the first direcction of the SRAm it should be: 14008200 33000010 04F8BF10 16FDBF00 However it's: 140020A8 33002872 04F89739 16FD581E It's like it only writes the 16 first bits of every 32bits. Connections are right, because if I run it with Eclipse, it runs correctly! What's happening?? - Altera_Forum
Yeap,the same exact problem here too.The weird thing is that i am able to run the program in the ram (or debug) (using the ide).With oscilloscope i am able to see data changing on address and data pins,but i don't see any data running on control pins of the ram (clk,ce,bwe,etc.) not in debug/run mode nor in regular mode
Following the advice by altera support i have performed a memory test for my external SSRAM-this was the output :
Testing RAM from 0x0 to 0x1FFFFF -Data bus test passed -Address bus test failed at address 0x80000
