15 years agoProblem booting program from EPCS flash and running from SRAM
Hardware and software tools: NIOS II IDE 10.1 ("Legacy") Quartus II 10.1 Device:Arria II GX - EP2AGX260FF35I5N I am using software tools and hardware as described and a custom board.The p...
15 years agoI have the same problem. If I link my program to the SRAM, it doesn't boot, but if I link to the Onchip_memory, without change any other parameter or the script, it boots!
I've checked what is written in the SRAM after boot, and it's not the right code, I don't no why! At the first direcction of the SRAm it should be: 14008200 33000010 04F8BF10 16FDBF00 However it's: 140020A8 33002872 04F89739 16FD581E It's like it only writes the 16 first bits of every 32bits. Connections are right, because if I run it with Eclipse, it runs correctly! What's happening??
