Porting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all,
I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 MCU and the NIOSII Eclipse Platform , version 9.1 for the nios ii/e cpu. ( e CPU: Cost and licence is based ). More details can bei obtained from my homepage. A) Performance issue: ARM-7: 12MHz clock , running at 48 Mhz via PLL. Nios II/e 50MHz clock , running at 50 Mhz. Used code: ( shifting LED Demo ) void startup_leds(void); void delay(void);# include <stdio.h># include <system.h># include "altera_avalon_pio_regs.h" // void startup_leds(void) { short is; short count = 4; int laufled = 0x00000001; for (count = 0; count < 4; count++ ) { for (is = 0; is < 16; is++ ) { IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, laufled); // IOPIN1 = laufled<<16; // was ARM-Code delay(); // wait laufled = laufled <<1; } for (is = 0; is < 16; is++ ) { //IOPIN1 = laufled<<16; // was ARM-Code IOWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, laufled); delay(); // wait laufled = laufled >>1; } } } // void delay(void) { short int wait = 6000; // arm-7: 50000 for same speed. while (wait) { wait = wait -1; } } // int main(void) { short count = 0; int delay; printf(" Hello from Nios II \n\r"); startup_leds(); while(1) { startup_leds(); } return 0; } Result. the arm-7 runs about 7 times faster than the nios ii/e ! Is the reason based on the Nios II/e CPU ? Maybe something wrong configured via SOPC Builder? Is my C-code correct? IOPIN1 = laufled<<16; = ARM-7 code with additional 16 ASR ! Converted to : OWR_ALTERA_AVALON_PIO_DATA(PIO_0_BASE, laufled); B) What is the recommendation reading Data from a PIO or test the condition from a single bits. For Example, I want to check the status of BIT-16. The ARM-7 C-code Statement if (!( IOPIN0 & 0x00010000 )) .... Nios II statement ? I was playing around with the IORDALTERA_AVALON_PIO_DATA(base) but without any success yet. Problem with SOPC Builder and PIO optional settings ? Everybody answer is welcome, Regards , Reinhard29 Replies
Ahhh, I didn't know that - thanks. We are using the "/f" NIOS II.
Bill A - Altera_Forum
I talked about the NIOSII/e core. Using a cache for the /s and /f core can improve the performance significantly.
Since you want maximum performance, why use /e?
Hi all,
this was a very interesting discussion for me with a lot of interesting informationen.Thank you very much. I am still surprised about the big performance difference, though and was of the opinion to port the ARM-7 data transfer C-code direct to Nios II. ( In my case, about 250Khz/16bit tranfer rate ) Now, I will redesign my project to run most of the design in pure hardware I am having a try now with SOPC DMA Controller Core. Regards, Reinhard - Altera_Forum
I'm doing a lot of 64k hdlc channels entirely in software (including bit-stuffing and crc). The problem I have at the moment is getting the data onto and off the fpga. For performance (and minimising the worst case):
- Use the /f core. - Put code and data into tightly coupled memory. - disable the data cache. - disable the instruction cache unless you need it for download. - Don't call anything in libc, and don't use the Altera supplied startup code. (you only need to set sp, gp and et). - Use gcc's __builtin_expect() to control which branches are taken. - Adjust the C source to avoid stalls following memory reads. - Ask your Altera FAE how to disable the dynamic branch predictor. Then, apart from the Avalon MM transfers to your target device, you'll have consistent instruction timings that match those documented. - Altera_Forum
Each call to the pio function results in 2 for loops that call the delay function 16 times which loops 6000 times. Each call therefore delays 32 times decrements 6000 times.
Actually I think they are embedded in a for that loops 4 times. The delay which simply decrements wait is really the only thing consuming cpu time. So the comparison is really showing how fast the different cpu's/programs can: load 1; load wait; subtract; store wait - 1; load 0; compare wait - 1, 0; if (true) return; else jump to load 1; Question 1: Did the compiler allocate registers or memory for the operands? Question 2: Is this loop sufficient to measure cpu performance? In other words, is it a good benchmark of cpu performance? - Altera_Forum
The delay() loop should end up being something like:
With the /f cpu, the add instruction takes 1 clock, the conditional branch (as coded) 2 clocks when going round the loop, and 4 when the loop exits. It is possible to get the branch to be 1 clock in the loop exit path - by jumping forwards to an unconditional branch and disabling the dynamic branch predictor. In this case the loop would be 4 + 2 clocks.delay: ori r2,r0,<loop count> # for a 16bit constant loop: add r2,r2,-1 bne r0,r2,loop ret - Altera_Forum
--- Quote Start --- The delay() loop should end up being something like:
With the /f cpu, the add instruction takes 1 clock, the conditional branch (as coded) 2 clocks when going round the loop, and 4 when the loop exits. It is possible to get the branch to be 1 clock in the loop exit path - by jumping forwards to an unconditional branch and disabling the dynamic branch predictor. In this case the loop would be 4 + 2 clocks. --- Quote End --- Thanks. This is a nice assembler loop, I agree. How do we know that the given C compiler would generate this optimized loop? Also you did not include cycles to fetch the instructions and progress thru the pipe to do the add register in 1 cycle. Also the objective was to compare two different cpu architectures by running C code generated by two different compilers. Also, the ori must be fetched and completed before the add can be done. That is something like 2-3 cycles memory access, plus 5 cycles thru the pipe. Assuming the add fetch was started a cycle after the ori fetch it is probably ready to execute, OK. Now the add result may be written to the register then compared, then the result used to determine the next instruction to fetch, then after the memory access it will start thru the pipe.delay: ori r2,r0,<loop count> # for a 16bit constant loop: add r2,r2,-1 bne r0,r2,loop ret - Altera_Forum
Hello and thanks for all the additional infos. Using the /f core NiosII results in my case with the error messages: Megafunction that supports opencore features will stop functioning in 1 hour after device is programmed. Reason: I don't have the correct licens to support the /f core. My network licence supports only the /e core. I also don't know how much does such a licence cost. If the CPU speed is really the "bottle-neck" , I would investigate to buy this licence or alternatively if the licence ist too expensive, I would prefere to install a ARM-7 based Header-Board ( eg. LPC-H21-03/-06/-24 from OLIMEX) on the DE1-Header connector.
--- Quote Start --- Thanks. This is a nice assembler loop, I agree. How do we know that the given C compiler would generate this optimized loop? Also you did not include cycles to fetch the instructions and progress thru the pipe to do the add register in 1 cycle. Also the objective was to compare two different cpu architectures by running C code generated by two different compilers. --- Quote End --- gcc will generate that code - probably from the given source - but it might need the variable changed to be 32bits (ie not a short). --- Quote Start --- Also, the ori must be fetched and completed before the add can be done. That is something like 2-3 cycles memory access, plus 5 cycles thru the pipe. Assuming the add fetch was started a cycle after the ori fetch it is probably ready to execute, OK. Now the add result may be written to the register then compared, then the result used to determine the next instruction to fetch, then after the memory access it will start thru the pipe. --- Quote End --- For the /f core, and executing from tightly coupled memory (or the instruction cache) the instruction fetches can be ignored. The pipeline loss for the call to the delay function would be attributed to the call instruction (and is 2 clocks). The 'ori' and 'add' and 'beq' execute in adjacent clocks, the backwards conditional branch will be (statically) predicted as taken - so be 2 clocks. Actually such a small function is probably best marked 'inline' (or as a# define) in order to make more registers available to the calling code. I've actually removed all subroutine calls from my code in order to give the compiler the best chance of not running out of registers. The only accesses to %sp are the pointless saving of the caller-saved registers on entry to a function that doesn't ever return!
