15 years agoPorting PIO C-code from ARM-7 to Nios II (SE1-board) + performance issue.
Hi all, I'm having a try at the moment to port my C-code from the arm-7 mcu, LPC-P2148 to Nios II, SE1-board , Cyclon-II, EP2C20F484C7. The arm-none-eabi-gcc compiler was used for the ARM-7 ...
15 years agoThe delay() loop should end up being something like:
delay:
ori r2,r0,<loop count> # for a 16bit constant
loop:
add r2,r2,-1
bne r0,r2,loop
ret With the /f cpu, the add instruction takes 1 clock, the conditional branch (as coded) 2 clocks when going round the loop, and 4 when the loop exits. It is possible to get the branch to be 1 clock in the loop exit path - by jumping forwards to an unconditional branch and disabling the dynamic branch predictor. In this case the loop would be 4 + 2 clocks.
