16 years agoNios II Flash Programmer with 8-bit CFI Interface
Hi All,
I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents Checksums took 0.0s Erase not required 00000000 ( 0%): Programming Program failed at offset E Leaving target processor paused Is there any solutions ? Regards, Hardik Sheth7 Replies
this could be due to several reasons.
but we would need more informations about your design. how did you setup the cfi flash inside sopcs ? how is your external cfi flash connected to the fpga, especialy the adr bus. yould you post some files of your project ? the sopcinfo file and the toplevel file that has the interface between the sopc design, which holds your cfi flash controller (via tristatebridge), and the external pins. - Altera_Forum
I have attached screen shot of my sopc and quartus system. Flash and FPGA data interface is 8-bit.
CFI Flash is M29W640FB. - Altera_Forum
your toplevel connectivity shows that sdram and cfi share some signals like adr ... is that correct ?
also your signal tri_bridge_byteenablen has goes to sdr_be is that correct ? the name ...byteenablen has a "n" at the end, might indicate negative logic. - Altera_Forum
I am having a similar problem. I have a system with:
UART (RS-232) + NIOS + ON-CHIP RAM, C program runs OK UART (RS-232) + NIOS + ON-CHIP RAM + DDR, get "leaving processor paused" problem. It does appear like a timing-related issue but I cannot find a proper .sdc generated by SOPC builder for the first case to improve on. What I see in the first case is that the clock frequency is set to 1 GHz as all clocks are (as if proper clock constraints are missing) through I set in SOPC builder the frequency of the input clock to the system to 144 MHz. The first case appears to work because it is a simple system. The second case with DDR appears to fail because the NIOS is now constrained differently. cpu.sdc does not contain any clock frequencies. I am using Quartus II 8.0 and NIOS 8.0 on Linux with OpenCore Plus evaluation mode. Any information would be appreciated. RAUL - Altera_Forum
--- Quote Start --- Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents Checksums took 0.0s Erase not required 00000000 ( 0%): Programming Program failed at offset E Leaving target processor paused Is there any solutions ? Regards, Hardik Sheth --- Quote End --- I had a similar problem and had to delay the control signals (to the FLASH) before they left the FPGA. I used a DFF and delayed the signals: read_n, write_n and select_n by one clock cycle. I found that the address lines were not stable by the time the control signals went active - that is why I delay them. I let them do inactive asynchronously by connecting the 'D' input of the flip flop to the 'preset' input through an inverter (not gate). - Altera_Forum
--- Quote Start --- I am having a similar problem. I have a system with: UART (RS-232) + NIOS + ON-CHIP RAM, C program runs OK UART (RS-232) + NIOS + ON-CHIP RAM + DDR, get "leaving processor paused" problem. It does appear like a timing-related issue but I cannot find a proper .sdc generated by SOPC builder for the first case to improve on. What I see in the first case is that the clock frequency is set to 1 GHz as all clocks are (as if proper clock constraints are missing) through I set in SOPC builder the frequency of the input clock to the system to 144 MHz. The first case appears to work because it is a simple system. The second case with DDR appears to fail because the NIOS is now constrained differently. cpu.sdc does not contain any clock frequencies. I am using Quartus II 8.0 and NIOS 8.0 on Linux with OpenCore Plus evaluation mode. Any information would be appreciated. RAUL --- Quote End --- Found out that the problem was a hanging NIOS reset_n pin. Once NIOS is properly reset the processor can be downloaded reliably. - Altera_Forum
good tip Praul - I will look at creating a reset first and look at its stability.
