16 years agoNios II Flash Programmer with 8-bit CFI Interface
Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test....
16 years agothis could be due to several reasons.
but we would need more informations about your design. how did you setup the cfi flash inside sopcs ? how is your external cfi flash connected to the fpga, especialy the adr bus. yould you post some files of your project ? the sopcinfo file and the toplevel file that has the interface between the sopc design, which holds your cfi flash controller (via tristatebridge), and the external pins.
