16 years agoNios II Flash Programmer with 8-bit CFI Interface
Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test....
16 years ago --- Quote Start --- Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK : Checksumming existing contents Checksums took 0.0s Erase not required 00000000 ( 0%): Programming Program failed at offset E Leaving target processor paused Is there any solutions ? Regards, Hardik Sheth --- Quote End --- I had a similar problem and had to delay the control signals (to the FLASH) before they left the FPGA. I used a DFF and delayed the signals: read_n, write_n and select_n by one clock cycle. I found that the address lines were not stable by the time the control signals went active - that is why I delay them. I let them do inactive asynchronously by connecting the 'D' input of the flip flop to the 'preset' input through an inverter (not gate).
