16 years agoNios II Flash Programmer with 8-bit CFI Interface
Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test....
16 years ago --- Quote Start --- I am having a similar problem. I have a system with: UART (RS-232) + NIOS + ON-CHIP RAM, C program runs OK UART (RS-232) + NIOS + ON-CHIP RAM + DDR, get "leaving processor paused" problem. It does appear like a timing-related issue but I cannot find a proper .sdc generated by SOPC builder for the first case to improve on. What I see in the first case is that the clock frequency is set to 1 GHz as all clocks are (as if proper clock constraints are missing) through I set in SOPC builder the frequency of the input clock to the system to 144 MHz. The first case appears to work because it is a simple system. The second case with DDR appears to fail because the NIOS is now constrained differently. cpu.sdc does not contain any clock frequencies. I am using Quartus II 8.0 and NIOS 8.0 on Linux with OpenCore Plus evaluation mode. Any information would be appreciated. RAUL --- Quote End --- Found out that the problem was a hanging NIOS reset_n pin. Once NIOS is properly reset the processor can be downloaded reliably.
