16 years agoNios II Flash Programmer with 8-bit CFI Interface
Hi All, I have 8-bit CFI Flash interface on my board. I got error .. # Programming flash with the datafile "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x02800000 "test....
16 years agoyour toplevel connectivity shows that sdram and cfi share some signals like adr ... is that correct ?
also your signal tri_bridge_byteenablen has goes to sdr_be is that correct ? the name ...byteenablen has a "n" at the end, might indicate negative logic.
