14 years agoNeed help::: Error: Node instance "XXX" instantiates undefined entity "XXX"
Hi all,
I am using nios processor to controll the userlogic(verilog) for my project.I have little experience with schematic entry. so I have created the symbol from the verilog code and I have connected both systems. When I try to compile my design I am getting this kind of errors. Error: Node instance "onchip_mem" instantiates undefined entity "processor18_onchip_mem" Error: Node instance "cpu18" instantiates undefined entity "processor18_cpu18" Error: Node instance "jtag_uart18" instantiates undefined entity "processor18_jtag_uart18" Those are just examples I am getting 64 errors(for each part I have used in processor ).Is there anyone having idea about this error. My final design should work exactly like as you see in the picture.5 Replies
Sorry for the previous post,
I forgot to add .qip file to my project.But still I have a problem.If you see the schematic you will find a bidirectional bus (data_pio_external to port_0_io ).Is it proper way of connecting bidirectional nodes.Because I am getting some Error: Port "port_0_io[0]" does not exist in macrofunction "inst". - Altera_Forum
You should only use bidirectional signals when connecting to i/o ports of the FPGA. Signals inside the FPGA can only go in one direction. I don't think Quartus can synthesize an internal bidirectional bus, it will probably stop with a multiple drivers error.
--- Quote Start --- Sorry for the previous post, I forgot to add .qip file to my project.But still I have a problem.If you see the schematic you will find a bidirectional bus (data_pio_external to port_0_io ).Is it proper way of connecting bidirectional nodes.Because I am getting some Error: Port "port_0_io[0]" does not exist in macrofunction "inst". --- Quote End --- " i am facing same problem for compilation, but i can't understang what the .qip file is and how to add it to project. please help." - Altera_Forum
Hi sarath
were you able to solve your problem with this Error (12006): Node instance "xxxx" instantiates undefined entity "xxxx" ? If you did, could you please explain how did you manage it? Thanks - Altera_Forum
This error means that you don't set you own library, yet. Go to assignments >> settings >> library (category field) >> add your library path, then apply it.
