14 years agoNeed help::: Error: Node instance "XXX" instantiates undefined entity "XXX"
Hi all, I am using nios processor to controll the userlogic(verilog) for my project.I have little experience with schematic entry. so I have created the symbol from the verilog code and I have c...
10 years agoThis error means that you don't set you own library, yet. Go to assignments >> settings >> library (category field) >> add your library path, then apply it.
