16 years ago
memory-to-memory sgdma problem
I am testing the sgdma core by copy data from one on-chip-memory buffer to the other.
However, I met a confusing problem that the actual_transfered_bytes is always zero.
Can anybody help?
the sopc-builder system i used is as follows:
cpu
-----instruction_master
-----data_master
on-chip memory
-----s1
sgdma_0
-----csr
-----descriptor_read
-----descriptor_write
-----m_read
-----m_write
descriptor_read, descriptor_read, m_read and m_write are connected to s1 of on-chip memory. csr is connected to data_master of cpu.
the c code is as follows:
alt_u32 tx_buf[10], rx_buf[10];
alt_sgdma_descriptor desc, next;
int main()
alt_u32 i;
alt_sgdma_dev *sgdma_m2m;
alt_u8 status;
for(i=0;i<10;i++){
tx_buf = i+0x11111111;
rx_buf = 0;
sgdma_m2m = alt_avalon_sgdma_open ("/dev/sgdma_0");
/* This will create a descriptor that is capable of transmitting data from an Avalon-MM buffer
* to a packet enabled Avalon-ST FIFO component */
alt_avalon_sgdma_construct_mem_to_mem_desc(
&desc, // descriptor
&next, // next descriptor
tx_buf, // read buffer location
rx_buf, // write buffer location
(alt_u16) 10, // length of the buffer
0, // reads are not from a fixed location
0); // writes are not from a fixed location
/* Prime the SGDMA engines with the descriptor lists (first one, it's a linked list) */
status = alt_avalon_sgdma_do_sync_transfer(sgdma_m2m, &desc);
return 0;
After alt_avalon_sgdma_do_sync_transfer() is called,
status is 0x0C which is as supposed, but desc.actual_transfered_bytes is zero!
The values in rx_buf[] remains the original values, all zeros.
Any comments will be appreciated.
    Is it possible to transfer data between two on-chip memory buffers with memory-to-memory sgdma?
    If you have a data cache enabled, it will probably prevent you from reading the updated values.
    You can use alt_remap_uncached() to change a pointer value to something that will force the CPU to bypass the cache.
    And yes it is possible. You can either transfer from and to the same memory, or between two different memories.
    The length of your buffer is 40 (10 words of 4 bytes each). Like others have said make sure the data isn't held in the cache.
    I can't remember if actual bytes transferred is supposed to update for MM->MM transaction types since there is no need to know it (you tell the DMA how much data to move). The actual bytes transferred field is meant for ST-->MM transactions with packet support enabled since you will not know how much data is arriving.
    I just got the right result after I had taken your advices.
    I used the function alt_remap_uncached() which is described in "Cache and Tightly Coupled memory" to transform the pointers, and the transfer size is indeed 40 instead of 10.
    Thanks all, especially Daixiwen.
    I recently made the sgdma work in the setup described in this topic but I'd like now to move data from one second on chip memory to a third one. I tried several ways to connect the sgdma to the memory blocks but it never works. I guess that the main problem is that the connection of the devices in the SOPC builder is not done correctly. Is there any place where I can find the purpose of the csr/descriptor_read/descriptor_write/m_read/m_write I/O of the SGDMA block ?
    The m_read/m_write master ports must be connected to the memories you want to read from/write to.
    The csr slave port must be connected to the CPU data master
    The descriptor_read/write master ports must be connected to the memory that holds the descriptor (usually the RAM that holds the .data section or the heap memory, depending on your code).
    Hello i didnt understand your code. Could you explain it pls? Where do you select the adress of the memories you want to read/write from and where are you seeing if everything is happening as planned (how are you debuggin?)
    alt_remap_uncached(), how to use this function in the code
