16 years agomemory-to-memory sgdma problem
Hello, I am testing the sgdma core by copy data from one on-chip-memory buffer to the other. However, I met a confusing problem that the actual_transfered_bytes is always zero. Can anybody he...
16 years agoI recently made the sgdma work in the setup described in this topic but I'd like now to move data from one second on chip memory to a third one. I tried several ways to connect the sgdma to the memory blocks but it never works. I guess that the main problem is that the connection of the devices in the SOPC builder is not done correctly. Is there any place where I can find the purpose of the csr/descriptor_read/descriptor_write/m_read/m_write I/O of the SGDMA block ?
