16 years agomemory-to-memory sgdma problem
Hello, I am testing the sgdma core by copy data from one on-chip-memory buffer to the other. However, I met a confusing problem that the actual_transfered_bytes is always zero. Can anybody he...
16 years agoThe m_read/m_write master ports must be connected to the memories you want to read from/write to.
The csr slave port must be connected to the CPU data master The descriptor_read/write master ports must be connected to the memory that holds the descriptor (usually the RAM that holds the .data section or the heap memory, depending on your code).
