16 years agomemory-to-memory sgdma problem
Hello, I am testing the sgdma core by copy data from one on-chip-memory buffer to the other. However, I met a confusing problem that the actual_transfered_bytes is always zero. Can anybody he...
15 years agoHello i didnt understand your code. Could you explain it pls? Where do you select the adress of the memories you want to read/write from and where are you seeing if everything is happening as planned (how are you debuggin?)
