14 years agoLoading image to SDRAM under ubuntu
I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage /opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory. Where is the mistake? Thanks in advance.35 Replies
My guess is that you need to add the quartus library directory containing the required so files to the LD_LIBRARY_PATH variable.
For Quartus v12.0 it should be located in <path-to-quartus>/12.0/quartus/linux64 where <path-to-quartus> depends on where you installed the software. Try this: export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:<path-to-quartus>/12.0/quartus/linux64; nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage N. - Altera_Forum
Thanks for ur reply sir,but i executed the nios2-download command its showing like this
alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage there is a problem with the quartus ii installation on your computer.please use `jtagconfig` for further diagnosis.
Kindly any help? Thanks, Alex.
Can you try executing that command as root? Just to check if it's a permission issue.
N. - Altera_Forum
Thanks you sir, tried as root but.......
alex@alex:~$ sudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage [sudo] password for alex: ***** sudo: nios2-download: command not found alex@alex:~$ gksudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage here it doesnt show any error but no output,just it return to command prompt alex@alex:~$ gksudo ./nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage here also it doesnt show any error but no output,just it return to command prompt Else i have to check like this or any other method? Where is the mistake? Thanks, Alex. - Altera_Forum
Sir,
For suppose if i got error like this (As mentioned below)there is a problem with the quartus ii installation on your computer.
please use `jtagconfig` for further diagnosis I came to know, i have to kill jtagd as mentioned below $ sudo killall jtagd $ sudo /opt/quartus/bin/jtagconfig -n Is it true? what i have to do? Kindly any help?
Try the following command to see if it resolves the jtag issue for normal users:
echo 'ATTR{idVendor}=="09fb", ATTR{idProduct}=="6001", MODE="666"' | sudo tee -a /lib/udev/rules.d/51-usbblaster.rules Reboot your machine just to make sure it takes effect. N. - Altera_Forum
Thanks for giving replies
still iam strucking there only Sir, once i close and again i open my terminal, if i type donload command 1.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage /opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory then i typed 2.alex@alex:~$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/quartus/linux and press enter alex@alex:~$ 3.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage there is a problem with the quartus ii installation on your computer.
please use `jtagconfig` for further diagnosis. i added the your line as u mentioned in the previous post And finally in my 51-usbblaster rules file is like this #usb-blaster
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6001", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6002", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6003", mode="0666"
echo 'attr{idvendor}=="09fb", attr{idproduct}=="6001", mode="666"' Y , once i close my terminal ,again i will open na no library path. I have to fix this problem, kindly any help? Where is the mistake? Thanks, Alex.
The last command I gave you was supposed to be executed only once.
In the archive attached to this post are two files: altera.conf -> put this one in /etc/ld.so.conf.d (this way you don't have to export the library path every time) 51-usbblaster.rules -> put this one in /lib/udev/rules.d Reboot your machine and try again. N. - Altera_Forum
Sir,
My usb blaster rules it is in /etc/udev/rules.d/51-usbblaster.rules,can i delete this one, imean as showed in my previous post According to you , i have to place /lib/udev/rules.d, in my path(/etc/udev/rules.d/51--usbblaster.rules) this file can i delete or what? Thanks, Alex. - Altera_Forum
Yes, you can overwrite the /lib/udev/rules.d/51-usbblaster.rules you created previously with the 51-usbblaster.rules in the zip file.
N.
