14 years agoLoading image to SDRAM under ubuntu
Hi, I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/...
14 years agoThanks for giving replies
still iam strucking there only Sir, once i close and again i open my terminal, if i type donload command 1.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage /opt/nios2eds/bin/nios2-gdb-server-wrapped: error while loading shared libraries: libjtag_client.so: cannot open shared object file: no such file or directory then i typed 2.alex@alex:~$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/quartus/linux and press enter alex@alex:~$ 3.alex@alex:~$ nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage there is a problem with the quartus ii installation on your computer.
please use `jtagconfig` for further diagnosis. i added the your line as u mentioned in the previous post And finally in my 51-usbblaster rules file is like this #usb-blaster
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6001", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6002", mode="0666"
bus=="usb", sysfs{idvendor}=="09fb", sysfs{idproduct}=="6003", mode="0666"
echo 'attr{idvendor}=="09fb", attr{idproduct}=="6001", mode="666"' Y , once i close my terminal ,again i will open na no library path. I have to fix this problem, kindly any help? Where is the mistake? Thanks, Alex.
