14 years agoLoading image to SDRAM under ubuntu
Hi, I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/...
14 years agoThanks you sir, tried as root but.......
alex@alex:~$ sudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage [sudo] password for alex: ***** sudo: nios2-download: command not found alex@alex:~$ gksudo nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage here it doesnt show any error but no output,just it return to command prompt alex@alex:~$ gksudo ./nios2-download -g ~/uClinux/distro/nios2-linux/uClinux-dist/images/zImage here also it doesnt show any error but no output,just it return to command prompt Else i have to check like this or any other method? Where is the mistake? Thanks, Alex.
