14 years agoLoading image to SDRAM under ubuntu
Hi, I am trying to run uclinux on DE0-Nano, and i successfully generated the zImage, but iam unable to load the image into SDRAM, it showing error like alex@alex:~$ nios2-download -g ~/...
14 years agoThe last command I gave you was supposed to be executed only once.
In the archive attached to this post are two files: altera.conf -> put this one in /etc/ld.so.conf.d (this way you don't have to export the library path every time) 51-usbblaster.rules -> put this one in /lib/udev/rules.d Reboot your machine and try again. N.
