IRQ mapping in SOPC builder
I fixed up the device address (na_usb - to the address assigned to ISP1362 in SOPC builder) and irq (na_usb_irq - IRQ 4 when viewed in SOPC builder) and corrected the chip id so linux recognizes the usb port, but i get the following error about the IRQ after i plug in a USB flash drive. I checked the DE2_NET design I'm using for this experiment in SOPC builder and the IRQ for ISP1362 is 4, or should i instead be using the IRQ for the DMA?
thanks in advance! io scheduler deadline registered 116x: driver isp116x-hcd, 08 Apr 2005 116x: ISP116x Host Controller, irq 4 isp116x-hcd isp116x-hcd: new USB bus registered, assigned bus number 1 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected scheduling while atomic: swapper/0x00000002/1 Stack from 00187d40:<0> <0> 00000002<0> 000d53cc<0> 00000001<0> ffffe000<0> 00002900<0> 001922ec< 0> 00189b20<0> 00356c00<0> <0> 40408180<0> 00000002<0> 000e5504<0> ffff8c59<0> 00000006<0> 000d696c< 0> 00150020<0> 00150020<0> <0> ffff8c59<0> 4b87ad6e<0> 000170f0<0> 00182d60<0> 0014fd50<0> 00000002< 0> ffffe000<0> 80000080<0> <0> 000175bc<0> 001921c0<0> 00192280<0> 000be790<0> 001921c0<0> 00192280< 0> 000bf130<0> 000df488<0> <0> 00000000<0> 00189a20<0> 0000000d<0> 000001f4<0> 00356c04<0> 00357d9c< 0> 000600fc<0> 00179200<0> <0> 0035ada4<0> 00000000<0> 00192294<0> 00356a00<0> 00000001<0> fffffffa< 0> ffffffed<0> 000ecc94<0> Call Trace:<0> <0> [<000bcf18>]<0> [<000a1e04>]<0> [<000a1eb8>]<0> [<00000001>]<0> <0> [<00000000>]<0> [<00000000>]<0> [<000a20a8>]<0> [<00000000>]<0> <0> [<000a0e68>]<0> [<00000000>]<0> [<00000000>]<0> [<000c5c68>]<0> <0> [<00000001>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<000001f4>]<0> [<00000001>]<0> [<00000000>]<0> [<000bf95c>]<0> <0> [<00000012>]<0> [<00000012>]<0> [<00000012>]<0> [<000c2034>]<0> <0> [<00000001>]<0> [<000a1e04>]<0> [<000a1f74>]<0> [<00000000>]<0> <0> [<000a22c8>]<0> [<00000001>]<0> [<000a2830>]<0> [<00000000>]<0> <0> [<00000000>]<0> [<00000264>]<0> [<00001d64>]<0> [<00006910>]<0> <0> [<00006968>]<0> [<0000088c>]<0> [<00000000>]<0> [<00000000>]<0> <0> [<00000000>]<0> [<000052a8>]<0> [<00000000>]<0> [<00000001>]<0> <0> [<00000b00>]<0> [<00000b00>]<0> [<0000019c>]<0> [<00000000>]<0> <0> [<00000120>]<0> [<00000001>]<0> [<00000001>]<0> [<00001d54>]<0> drivers/usb/class/bluetty.c: USB Bluetooth support registered usbcore: registered new driver bluetty drivers/usb/class/bluetty.c: USB Bluetooth tty driver v0.13 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. Freeing unused kernel memory: 348k freed (0xf2000 - 0x148000) init started: BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # usb 1-2: new full speed USB device using isp116x-hcd and address 2 isp116x-hcd isp116x-hcd: Unlink after no-IRQ? Controller is probably using the wrong IRQ.19 Replies
Shindou,
Good found, It looks like the piece of driver you need. you have to update your arch/nios2nommu/kerbel/usb.c to prepare for the probing of the 1362 hcd. You should enable the debug message, too. You have to "port" the driver to your nios2 board. (it is not plug-and-play...). The 1362 hcd should detected first, then the root hub. Then when a usb disk inserted it will detect the new usb mas storage device, and display the usb disk info. - Altera_Forum
<div class='quotetop'>QUOTE </div>
--- Quote Start --- driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd.0: ISP1362 Host Controller isp1362_hc_reset: isp1362-hcd isp1362-hcd.0: new USB bus registered, assigned bus number 1 isp1362-hcd isp1362-hcd.0: irq 28, io mem 0x0c000000 isp1362_hc_start: isp1362-hcd isp1362-hcd.0: ISP1362 Memory usage: isp1362-hcd isp1362-hcd.0: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd.0: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd.0: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd.0: USED/FREE: 3968 128 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 28 usbcore: registered new driver cdc_acm drivers/usb/class/cdc-acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters usbcore: registered new driver usblp drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. usbcore: registered new driver usbhid drivers/usb/input/hid-core.c: v2.01:USB HID core driver pegasus: v0.6.12 (2005/01/13), Pegasus/Pegasus II USB Ethernet driver usbcore: registered new driver pegasus [/b] --- Quote End --- This is what I found from the net, about the boot log of isp1362 on arm. I am trying to add isp1362-hcd to nios2 kernel, and will let you know when I compile through. I can not borrow a DEII board, so it is up to you to test them. - Altera_Forum
Shindou,
Please find the isp1362.zip attached in post#1 of buildroot guide.
rebuild the kernel from hwselect,menuconfig .cd ~/download unzip isp1362.zip cd ~/linux-2.6.16.1 patch -p0 <~/download/isp1362-nios2-01.diff - Altera_Forum
thanks hippo, just tried it out with the nios_0.ptf
uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6508k/8192k RAM, 0k/0k ROM (1136k kernel code, 452k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub Bluetooth: Core ver 2.8 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart usbmon: debugfs is not available Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. Bluetooth: HCI USB driver ver 2.9 usbcore: registered new driver hci_usb Freeing unused kernel memory: 352k freed (0x12a000 - 0x181000) init started: BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) Built-in shell (msh) Enter 'help' for a list of built-in commands. # didn't see anything pop up when i plugged in a usb flash drive though. i'll update the thread as i debug if i find anything or get it to work. - Altera_Forum
it didn't initialize the isp1362-hcd,
Did you select isp1362 hcd in kernel menuconfig? Try add some printk and debug to the code, arch/nios2nommu/kernel/usb.c and drivers/usb/host/isp1362-hcd.c . - Altera_Forum
It seems like it's getting to the usb_hcd_init() call in arch/nios2nommu/kernel/usb.c where platform_device_register(&isp1362_hcd) is called but it seems the init code in drivers/usb/host/isp1362-hcd.c (ie. isp1362_init() is never called)
last edit: Yep, ISP1362 HCD is selected in the menuconfig - hmm, interesting point tho, there's no object file after the make (ISP1362-hcd.o) in the drivers/usb/host directory. It's strange tho, the code in an adjacent directory drivers/usb/core had object files. Probably explains the problem above why that code never got called. Gonna see if i can figure out why this makefile isn't compiling isp1362-hcd.c. - Altera_Forum
try make clean, and rebuild kernel from hwselect again.
I did try compile with DE2 ptf . there should be the isp1362-hcd.o . - Altera_Forum
Found the problem, the Makefile in the drivers/usb didn't point to the drivers/usb/host directory for ISP1362 selection in menuconfig.
io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart usbmon: debugfs is not available driver isp1362-hcd, 2005-04-04 isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362_hc_reset: Clock not ready after 20ms isp1362-hcd isp1362-hcd: can't reset init error, -19 Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. Bluetooth: HCI USB driver ver 2.9 usbcore: registered new driver hci_usb Freeing unused kernel memory: 352k freed (0x13c000 - 0x193000) init started: BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary can start debugging the reset problem now - Altera_Forum
--- Quote Start --- originally posted by shindou@Apr 6 2006, 09:18 AM found the problem, the makefile in the drivers/usb didn't point to the drivers/usb/host directory for isp1362 selection in menuconfig.io scheduler noop registered
serial: jtag uart driver $revision: 1.4 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362_hc_reset:
clock not ready after 20ms
init error, -19
initializing usb mass storage driver...
usb mass storage support registered.
bluetooth: hci usb driver ver 2.9
freeing unused kernel memory: 352k freed (0x13c000 - 0x193000)
init started: busybox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14079)
--- quote end ---
--- Quote End --- yes, drivers/usb/Makefile line17 should be changed to ISP1362 . let me know if you have progress in the debug http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
