20 years agoIRQ mapping in SOPC builder
I fixed up the device address (na_usb - to the address assigned to ISP1362 in SOPC builder) and irq (na_usb_irq - IRQ 4 when viewed in SOPC builder) and corrected the chip id so linux recognizes the ...
20 years agoShindou,
Good found, It looks like the piece of driver you need. you have to update your arch/nios2nommu/kerbel/usb.c to prepare for the probing of the 1362 hcd. You should enable the debug message, too. You have to "port" the driver to your nios2 board. (it is not plug-and-play...). The 1362 hcd should detected first, then the root hub. Then when a usb disk inserted it will detect the new usb mas storage device, and display the usb disk info.
