20 years agoIRQ mapping in SOPC builder
I fixed up the device address (na_usb - to the address assigned to ISP1362 in SOPC builder) and irq (na_usb_irq - IRQ 4 when viewed in SOPC builder) and corrected the chip id so linux recognizes the ...
20 years ago --- Quote Start --- originally posted by shindou@Apr 6 2006, 09:18 AM found the problem, the makefile in the drivers/usb didn't point to the drivers/usb/host directory for isp1362 selection in menuconfig.
io scheduler noop registered
io scheduler deadline registered (default)
serial: jtag uart driver $revision: 1.4 $
ttyj0 at mmio 0x81004000 (irq = 1) is a jtag_uart
usbmon: debugfs is not available
driver isp1362-hcd, 2005-04-04
isp1362-hcd isp1362-hcd: isp1362 host controller
isp1362_hc_reset:
clock not ready after 20ms
isp1362-hcd isp1362-hcd: can't reset
init error, -19
initializing usb mass storage driver...
usbcore: registered new driver usb-storage
usb mass storage support registered.
bluetooth: hci usb driver ver 2.9
usbcore: registered new driver hci_usb
freeing unused kernel memory: 352k freed (0x13c000 - 0x193000)
init started: busybox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary
can start debugging the reset problem now
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14079)
--- quote end ---
--- Quote End --- yes, drivers/usb/Makefile line17 should be changed to ISP1362 . let me know if you have progress in the debug http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
