20 years agoinstall "Nios II Linux v1.4 released"
hi!
i've just tried to install the downloaded linux. there was an error message: "Cygwin extension were not installed properly. Please see README for instruction on how to install them manually" what does that mean? could not find a hint in README on how to install them manually. system : XP, quartus v51, nios v51. torsten15 Replies
--- Quote Start --- originally posted by hootsmon@Apr 26 2006, 11:49 AM here is my patch to make elf2flt compile properly on debian platform....index: toolchain/elf2flt/elf2flt.mk =================================================================== --- toolchain/elf2flt/elf2flt.mk (original) +++ toolchain/elf2flt/elf2flt.mk (working copy) @@ -20,6 +20,7 @@ (cd $(elf2flt_dir); rm -rf config.cache; $(elf2flt_dir)/configure --with-bfd-include-dir=$(binutils_dir1)/bfd/ + --with-binutils-include-dir=$(binutils_dir)/include/ --target=$(real_gnu_target_name) --with-libbfd=$(binutils_dir1)/bfd/libbfd.a --with-libiberty=$(binutils_dir1)/libiberty/libiberty.a \thorsten, here's how to apply it....
1) save the patch into ~/download/elf2flt.diff
2) cd ~/buildroot
3) patch -p0 <~/download/elf2flt.diff
4) rm -rf toolchain_build_nios2/elf2flt
5) make
hippo, does this patch look allright to you?
will it have any affect on non-debian users?
should something like this go in svn?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14680)</div> --- Quote End --- Hootsmon, I have tested the patch on FC5. The elf2flt works well. Good job. Could you post the patch to buildroot group of bug report on busybox.net ?
--- Quote Start --- originally posted by hippo@Apr 28 2006, 12:55 AM hootsmon,i have tested the patch on fc5. the elf2flt works well. good job.
could you post the patch to buildroot group of bug report on busybox.net ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14765)
--- quote end ---
--- Quote End --- Thanks hippo, I'll post it.
hello!
try to do the patch. saved your code in elf2flt.diff in directory "download". try to run the given command. here is the result. sorry, did i forgot something (permissions, line of codes ...)? should i do the cjange by hand? _____________________________________________________________________ grev@mhfppcx7974note:~/buildroot$ patch -p0 <~/download/elf2flt.diff patching file toolchain/elf2flt/elf2flt.mk Hunk# 1 FAILED at 20. 1 out of 1 hunk FAILED -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej grev@mhfppcx7974note:~/buildroot$ 5~ --------------------------------------------------------------- kind regards torsten - Altera_Forum
--- Quote Start --- originally posted by torsten grevsmuehl@May 2 2006, 07:35 PM hello!try to do the patch. saved your code in elf2flt.diff in directory "download".
hunk# 1 failed at 20.
1 out of 1 hunk failed -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14937)
--- quote end ---
--- Quote End --- Add "-l" option to patch command to ignore white space in patch file.
hello hippo! hello hootsmon!
removed all dir. put patch command (with option -l) into buildscript. let buildscript run like it did the first time.did not observe output of buildscript nor put it to a file. here the last lines taken from commandline:
so everything seems to be in the right place now. is there a quick check if it is working or should one simply proceed with hippo's thread? next: how to keep the things up to date? kind regards to all involved solving my questions torsten~/buildroot/build_nios2/root/usr/bin/uniq -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/unix2dos -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/unzip -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uptime -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uudecode -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/uuencode -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/vlock -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/wc -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/wget -> ../../bin/busybox ~/buildroot/build_nios2/root/usr/bin/which -> ../../bin/busybox make: Leaving directory `~/buildroot/build_nios2/busybox'# Just in case chmod a+x ~/buildroot/build_nios2/root/usr/share/udhcpc/default.script
