20 years agoinstall "Nios II Linux v1.4 released"
hi! i've just tried to install the downloaded linux. there was an error message: "Cygwin extension were not installed properly. Please see README for instruction on how to install them ...
20 years agohello!
try to do the patch. saved your code in elf2flt.diff in directory "download". try to run the given command. here is the result. sorry, did i forgot something (permissions, line of codes ...)? should i do the cjange by hand? _____________________________________________________________________ grev@mhfppcx7974note:~/buildroot$ patch -p0 <~/download/elf2flt.diff patching file toolchain/elf2flt/elf2flt.mk Hunk# 1 FAILED at 20. 1 out of 1 hunk FAILED -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej grev@mhfppcx7974note:~/buildroot$ 5~ --------------------------------------------------------------- kind regards torsten
