20 years agoinstall "Nios II Linux v1.4 released"
hi! i've just tried to install the downloaded linux. there was an error message: "Cygwin extension were not installed properly. Please see README for instruction on how to install them ...
20 years ago --- Quote Start --- originally posted by torsten grevsmuehl@May 2 2006, 07:35 PM hello!
try to do the patch. saved your code in elf2flt.diff in directory "download".
try to run the given command. here is the result. sorry, did i forgot something
(permissions, line of codes ...)? should i do the cjange by hand?
_____________________________________________________________________
grev@mhfppcx7974note:~/buildroot$ patch -p0 <~/download/elf2flt.diff
patching file toolchain/elf2flt/elf2flt.mk
hunk# 1 failed at 20.
1 out of 1 hunk failed -- saving rejects to file toolchain/elf2flt/elf2flt.mk.rej
grev@mhfppcx7974note:~/buildroot$ 5~
kind regards torsten
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14937)
--- quote end ---
--- Quote End --- Add "-l" option to patch command to ignore white space in patch file.
