20 years agoinstall "Nios II Linux v1.4 released"
hi! i've just tried to install the downloaded linux. there was an error message: "Cygwin extension were not installed properly. Please see README for instruction on how to install them ...
20 years agohello hippo! hello hootsmon!
removed all dir. put patch command (with option -l) into buildscript. let buildscript run like it did the first time.did not observe output of buildscript nor put it to a file. here the last lines taken from commandline:
~/buildroot/build_nios2/root/usr/bin/uniq -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/unix2dos -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/unzip -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uptime -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uudecode -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/uuencode -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/vlock -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/wc -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/wget -> ../../bin/busybox
~/buildroot/build_nios2/root/usr/bin/which -> ../../bin/busybox
make: Leaving directory `~/buildroot/build_nios2/busybox'# Just in case
chmod a+x ~/buildroot/build_nios2/root/usr/share/udhcpc/default.script so everything seems to be in the right place now. is there a quick check if it is working or should one simply proceed with hippo's thread? next: how to keep the things up to date? kind regards to all involved solving my questions torsten
