20 years agoHow to build uclinux to DE2 board ,please help!
hi,everybody,
I have a DE2 board and I want to install uclinux onto the board as the OS,but I got some difficulties,would you please info me some files or give me some links that about the whole process of the installation.Including the boarc hardware drives will be better. Thank you very much.16 Replies
--- Quote Start --- originally posted by lonsta@Jul 14 2006, 04:32 PM hi,everybody,i have a de2 board and i want to install uclinux onto the board as the os,but
i got some difficulties,would you please info me some files or give me some links
that about the whole process of the installation.including the boarc hardware drives
will be better.
thank you very much.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16894)
--- quote end ---
--- Quote End --- follow the wiki, step 1-3 http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux) First, try out the prebuilt kernel.
Thanks for your answer ,I am working on it now,but there's something that confuse me ,as below:
------------------------ [hhh@localhost uClinux-dist-test]$ make linux_hwselect SYSPTF=nios_0.ptf KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x hwselect no emulation specific options. make[1]: Entering directory `/home/mxp/uClinux-dist-test/linux-2.6.x' RUNNING hwselect --- Please select which CPU you wish to build the kernel against: (1) cpu_0 - Class: altera_nios2 Type: f Version: 5.0 Selection: <<<--------------------------------Q,here Invalid response, please try again. Selection: niosII Invalid response, please try again. --------------------------------------------------- It's the third step ...But , I don't kown "Selection" WHAT,and I didn't find the answer in the Wiki , what should I select ,I work on the DE2 board, trapped in this step ,I cannot go ahead ,so would you please info me more files that could help understand kernel-building process in details?Thanks a lot ! - Altera_Forum
--- Quote Start --- originally posted by lonsta@Jul 15 2006, 04:41 PM thanks for your answer ,i am working on it now,but there's something that confuse me ,as below:------------------------
[hhh@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_0.ptf
kconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
make[1]: entering directory `/home/mxp/uclinux-dist-test/linux-2.6.x'
running hwselect
--- please select which cpu you wish to build the kernel against:
(1) cpu_0 - class: altera_nios2 type: f version: 5.0
selection: <<<--------------------------------q,here
invalid response, please try again.
selection: niosii
it's the third step ...but ,
i don't kown "selection" what,and i didn't find the answer in the wiki , what should i select ,i work
on the de2 board, trapped in this step ,i cannot go ahead ,so would you please info me more files that could help understand kernel-building process in details?thanks a lot !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16936)
--- quote end ---
--- Quote End --- (1) cpu_0 - Class: altera_nios2 Type: f Version: 5.0 Selection: <<<--------------------------------Q,here Invalid response, please try again. Selection: 1 -----------this will b eok,you may try
Thanks ,it works,but the next step got a problem ,please ,when I make romfs,the result is as below,I know it can be ignored...
----------------------------------------------------------- [mxp@localhost uClinux-dist-test]$ make romfs# to creat romfs dir,make will fail,ignored for dir in vendors include lib include user ; do [ ! -d $dir ] || make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C $dir romfs || exit 1 ; done make[1]: Entering directory `/home/mxp/uClinux-dist-test/vendors' make -C /home/mxp/uClinux-dist-test/vendors/Altera/nios2nommu/. dir_v=/home/mxp/uClinux-dist-test/vendors/Altera/nios2nommu/. -f /home/mxp/uClinux-dist-test/vendors/vendors-common.mak romfs make[2]: Entering directory `/home/mxp/uClinux-dist-test/vendors/Altera/nios2nommu' [ -d /home/mxp/uClinux-dist-test/romfs/$i ] || mkdir -p /home/mxp/uClinux-dist-test/romfs for i in bin dev etc etc/config etc/default home lib mnt proc usr var sys; do [ -d /home/mxp/uClinux-dist-test/romfs/$i ] || mkdir -p /home/mxp/uClinux-dist-test/romfs/$i; done romfs-inst.sh -s /var/tmp /tmp romfs-inst.sh ../../Generic/romfs / 24 blocks romfs-inst.sh -s /bin/init /init romfs-inst.sh /etc/inittab romfs-inst.sh /etc/rc echo "Altera/nios2nommu Version 3.2.0 -- " `date` > /home/mxp/uClinux-dist-test/romfs/etc/version make[2]: Leaving directory `/home/mxp/uClinux-dist-test/vendors/Altera/nios2nommu' make[1]: Leaving directory `/home/mxp/uClinux-dist-test/vendors' make[1]: Entering directory `/home/mxp/uClinux-dist-test/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/home/mxp/uClinux-dist-test/include' make[1]: Entering directory `/home/mxp/uClinux-dist-test/lib' romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/passwd /etc/passwd romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/group /etc/group romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/mtab /etc/mtab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/fstab /etc/fstab romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -s config/resolv.conf /etc/resolv.conf romfs-inst.sh -e CONFIG_USER_FLATFSD_FLATFSD -e CONFIG_USER_TINYLOGIN_SHADOWPASSWDS -s config/shadow /etc/shadow for i in ../include ../include /home/mxp/uClinux-dist-test/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/home/mxp/uClinux-dist-test/include' make[2]: Nothing to be done for `romfs'. make[2]: Leaving directory `/home/mxp/uClinux-dist-test/include' make[2]: Entering directory `/home/mxp/uClinux-dist-test/include' make[2]: Nothing to be done for `romfs'. make[2]: Leaving directory `/home/mxp/uClinux-dist-test/include' make[1]: Leaving directory `/home/mxp/uClinux-dist-test/lib' make[1]: Entering directory `/home/mxp/uClinux-dist-test/include' make[1]: Nothing to be done for `romfs'. make[1]: Leaving directory `/home/mxp/uClinux-dist-test/include' make[1]: Entering directory `/home/mxp/uClinux-dist-test/user' for i in busybox games inetd init sash telnetd /home/mxp/uClinux-dist-test/prop ; do [ ! -d $i ] || make -C $i romfs || exit $? ; done make[2]: Entering directory `/home/mxp/uClinux-dist-test/user/busybox' make[2]: *** 没有规则可以创建目标“romfs”。 停止。 make[2]: Leaving directory `/home/mxp/uClinux-dist-test/user/busybox' make[1]: *** [romfs] 错误 2 make[1]: Leaving directory `/home/mxp/uClinux-dist-test/user' make: *** [romfs.subdirs] 错误 1 [mxp@localhost uClinux-dist-test]$ ls autoconf.h config.arch Documentation lib linux-2.6.x openswan SOURCE uClinux-dist.diff.gz bin config.in freeswan linux-2.0.x Makefile README tools user config COPYING include linux-2.4.x nios_0.ptf romfs uClib -------------------------------------------------------------------------------------------------------------------- Here- Since I ignore the "'fail"",and I then make menuconfig ,the result is as below , it produded error,what it means,and how should I make it ?I nearly got it ,it's the last step,please help,Thanks so much. _____________________________________________________________________________ [mxp@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/mxp/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' make[1]: Leaving directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' Using defaults found in .config Preparing scripts: functions, parsing...done. Saving your kernel configuration... *** End of Linux kernel configuration. *** Check the top-level Makefile for additional configuration. *** Next, you must run 'make dep'. make[1]: Entering directory `/home/mxp/uClinux-dist-test' KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x menuconfig /bin/sh: nios2-linux-uclibc-gcc: command not found make[2]: nios2-linux-uclibc-gcc:命令未找到 make[2]: Entering directory `/home/mxp/uClinux-dist-test/linux-2.6.x' /home/mxp/uClinux-dist-test/linux-2.6.x/arch/nios2nommu/Makefile:127: *** Run "make hwselect SYSPTF=<system.ptf>" first。 停止。 make[2]: Leaving directory `/home/mxp/uClinux-dist-test/linux-2.6.x' make[1]: *** [linux_menuconfig] 错误 2 make[1]: Leaving directory `/home/mxp/uClinux-dist-test' make: *** [menuconfig] 错误 2 [mxp@localhost uClinux-dist-test]$ - Altera_Forum
in step 2 of the wiki, install the PATH of the nios2 gcc.
Thanks very much ,I made it ,boot the uclinux on the DE2 ,but the second time ,I got an error
that I've never seen before,It's as below .I use the .ptf file of the example in the DE2 DISK,so I think it seems not the problem of .ptf file itselt,so what's the problem and how should I solve it ? ----------------------------------------------------------------------------------- [mxp@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/mxp/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' make[1]: Leaving directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' Using defaults found in .config Preparing scripts: functions, parsing...done. Saving your kernel configuration... *** End of Linux kernel configuration. *** Check the top-level Makefile for additional configuration. *** Next, you must run 'make dep'. [mxp@localhost uClinux-dist-test]$ make linux_hwselect SYSPTF=nios_0.ptf KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x hwselect no emulation specific options. make[1]: Entering directory `/home/mxp/uClinux-dist-test/linux-2.6.x' RUNNING hwselect ERROR: Could not open SYSTEM ptf file. //<------Q Here. make[1]: Leaving directory `/home/mxp/uClinux-dist-test/linux-2.6.x' [mxp@localhost uClinux-dist-test]$ [mxp@localhost uClinux-dist-test]$ ls autoconf.h COPYING linux-2.0.x openswan uClinux-dist.diff.gz bin Documentation linux-2.4.x README user config freeswan linux-2.6.x SOURCE vendors config.arch include Makefile tools config.in lib nios_0.ptf uClibc [mxp@localhost uClinux-dist-test]$ - Altera_Forum
--- Quote Start --- originally posted by lonsta@Jul 17 2006, 09:00 AM [mxp@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_0.ptfkconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
running hwselect
error: could not open system ptf file. //<------q here.
make[1]: leaving directory `/home/mxp/uclinux-dist-test/linux-2.6.x'
[mxp@localhost uclinux-dist-test]$ ls
autoconf.h copying linux-2.0.x openswan uclinux-dist.diff.gz
bin documentation linux-2.4.x readme user
config freeswan linux-2.6.x source vendors
config.arch include makefile tools
config.in lib nios_0.ptf uclibc
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16959)
--- quote end ---
--- Quote End --- The ptf has to be in the linux-2.6.x directory OR you have to give "make linux_hwselect" the absolute dir of your ptf. So copy the nios_0.ptf to linux-2.6.x dir or run "make linux_hwselect SYSPTF=/home/mxp/uClinux-dist-test/nios_0.ptf". Hope this helps, it worked for me.
Thanks so much! It did work.!I've made it . And then I have two questions here ..
1.What should I do if I want to run my own application programme ,that is to say, I wish some programme run just when the system have booted automatically,are there any steps that I must follow? I've read of documents on the kernel-start and the system initial , but still I'm a little puzzled .Is the whole boot and initial process of uclinux same with linux OS? I will be appreciate if you could info me some documents or links. 2. I've leaned ARM linux for a short time .But I want to know how to debug my app programme under uclinux ,like under linux,we can debug through TFTP &mount or NFS or zmodern e.g.But how under uclinux,are there any method and develop tools that could help us to cross compile&run&debug in the application level (not cross-compile on kernel level ),just like arm-linux ,when we finish the kernel ,we can focus on the application development. Thanks a lot . - Altera_Forum
great!
1. see the wiki, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist) <div class='quotetop'>QUOTE </div> --- Quote Start --- The simplified "init" program will run etc/rc and etc/inittab during startup. If you want to customize startup, you should update the files vendors/Altera/nios2nommu/ rc and inittab.[/b] --- Quote End --- 2. yes, you can use tftp, ftp, http or nfs mount to develope apps. there are tftp, wget, and mount (for nfs) in busybox. you can enable them with make menuconfig in uClinux-dist-test . http://nioswiki.jot.com/wikihome/operating...ms/nfsfilesytem (http://nioswiki.jot.com/wikihome/operatingsystems/nfsfilesytem) - Altera_Forum
Thanks for hippo's advise,following the" NFSFileSystem "step by step ,when I download the kernel (include busybox->mount, nfs file support ,and default kernel)
I got a problem as below: />mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.11.17:/home/mxp/nios2 /mnt/nfs //my server ip mount : cannot read /etc/fstab :No such file or directory /etc>ls config default inetd.conf inittab motd rc services version /etc> however,after a short time ,(I just debug carefully,unkowning why)it becomes: />mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.11.17:/home/mxp/nios2 /mnt/nfs mount:RPC: Unable to receive ;error = No route to Host mount:nfsmount failed; Bad file descriptor mount:mount on .168.11.17:/home/mxp/nios2 /mnt/nfs failed />busybox mount //it's okey,but added with the parameters //it got the same error msg like above. The sopc Builder sdk shell display like above, I know that "mount "informations are all in the "etc/fstab" file ,surely this "/etc/fstab" is supposed to be on the board uclinuxOS,not the one on the linux host ,but but how could I make the" fstab "onto the board ,which should I choose when I config the kernel in the "customize vendor/user setting "menu and "customize kernel setting"menu? Trouble you for another quesion,in the "customize vendor/user setting "menu, I found that the same bash command (e.g.ping etc.)exits in different submenu, I want to know what is the difference of them and what useness are these submenus . Thanks a lot.
