20 years agoHow to build uclinux to DE2 board ,please help!
hi,everybody, I have a DE2 board and I want to install uclinux onto the board as the OS,but I got some difficulties,would you please info me some files or give me some links that abou...
20 years ago --- Quote Start --- originally posted by lonsta@Jul 17 2006, 09:00 AM [mxp@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_0.ptf
kconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
no emulation specific options.
make[1]: entering directory `/home/mxp/uclinux-dist-test/linux-2.6.x'
running hwselect
error: could not open system ptf file. //<------q here.
make[1]: leaving directory `/home/mxp/uclinux-dist-test/linux-2.6.x'
[mxp@localhost uclinux-dist-test]$ ls
autoconf.h copying linux-2.0.x openswan uclinux-dist.diff.gz
bin documentation linux-2.4.x readme user
config freeswan linux-2.6.x source vendors
config.arch include makefile tools
config.in lib nios_0.ptf uclibc
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16959)
--- quote end ---
--- Quote End --- The ptf has to be in the linux-2.6.x directory OR you have to give "make linux_hwselect" the absolute dir of your ptf. So copy the nios_0.ptf to linux-2.6.x dir or run "make linux_hwselect SYSPTF=/home/mxp/uClinux-dist-test/nios_0.ptf". Hope this helps, it worked for me.
