20 years agoHow to build uclinux to DE2 board ,please help!
hi,everybody, I have a DE2 board and I want to install uclinux onto the board as the OS,but I got some difficulties,would you please info me some files or give me some links that abou...
20 years ago --- Quote Start --- originally posted by lonsta@Jul 15 2006, 04:41 PM thanks for your answer ,i am working on it now,but there's something that confuse me ,as below:
[hhh@localhost uclinux-dist-test]$ make linux_hwselect sysptf=nios_0.ptf
kconfig_notimestamp=1 make arch=nios2nommu cross_compile=nios2-linux-uclibc- arch=nios2nommu cross_compile=nios2-linux-uclibc- -c linux-2.6.x hwselect
no emulation specific options.
make[1]: entering directory `/home/mxp/uclinux-dist-test/linux-2.6.x'
running hwselect
--- please select which cpu you wish to build the kernel against:
(1) cpu_0 - class: altera_nios2 type: f version: 5.0
selection: <<<--------------------------------q,here
invalid response, please try again.
selection: niosii
it's the third step ...but ,
i don't kown "selection" what,and i didn't find the answer in the wiki , what should i select ,i work
on the de2 board, trapped in this step ,i cannot go ahead ,so would you please info me more files that could help understand kernel-building process in details?thanks a lot !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16936)
--- quote end ---
--- Quote End --- (1) cpu_0 - Class: altera_nios2 Type: f Version: 5.0 Selection: <<<--------------------------------Q,here Invalid response, please try again. Selection: 1 -----------this will b eok,you may try
