20 years agoHow to build uclinux to DE2 board ,please help!
hi,everybody, I have a DE2 board and I want to install uclinux onto the board as the OS,but I got some difficulties,would you please info me some files or give me some links that abou...
20 years agoThanks very much ,I made it ,boot the uclinux on the DE2 ,but the second time ,I got an error
that I've never seen before,It's as below .I use the .ptf file of the example in the DE2 DISK,so I think it seems not the problem of .ptf file itselt,so what's the problem and how should I solve it ? ----------------------------------------------------------------------------------- [mxp@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/mxp/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' make[1]: Leaving directory `/home/mxp/uClinux-dist-test/config/scripts/lxdialog' Using defaults found in .config Preparing scripts: functions, parsing...done. Saving your kernel configuration... *** End of Linux kernel configuration. *** Check the top-level Makefile for additional configuration. *** Next, you must run 'make dep'. [mxp@localhost uClinux-dist-test]$ make linux_hwselect SYSPTF=nios_0.ptf KCONFIG_NOTIMESTAMP=1 make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -C linux-2.6.x hwselect no emulation specific options. make[1]: Entering directory `/home/mxp/uClinux-dist-test/linux-2.6.x' RUNNING hwselect ERROR: Could not open SYSTEM ptf file. //<------Q Here. make[1]: Leaving directory `/home/mxp/uClinux-dist-test/linux-2.6.x' [mxp@localhost uClinux-dist-test]$ [mxp@localhost uClinux-dist-test]$ ls autoconf.h COPYING linux-2.0.x openswan uClinux-dist.diff.gz bin Documentation linux-2.4.x README user config freeswan linux-2.6.x SOURCE vendors config.arch include Makefile tools config.in lib nios_0.ptf uClibc [mxp@localhost uClinux-dist-test]$
