17 years ago
how can i get the memory map file.
in a design , using several memory, flash , ddr, and ssram , after enter into the nios2 to setup a project, after building the project, i want to know each section 's address. but i can not find the corresponding file.
    You can either find it in the HTML datasheet generated by SOPC builder (in the same folder than the PTF file) or in the IDE itself, in a header file. Go in the syslib -> Debug -> system_description -> system.h
    The two files: *.html and system.h file can not give a detailed description of each section 's address, such as begining address,end address,section size, ect.
    This two files only give the hardware system's address, such as the ddr2 sdram 's address, flash 's address. On this cpu.ptf, i set up several software project, each project has diffrent software size. So the Nios2 should give a file descriping each section 's address. I can not find that file or information.:p
    The information is embedded in the elf file. You can retreive it using a command in the Nios shell. Something like:
    nios2-elf-size -Ax my_project.elf
    thanks , i have tried and the address map displayed on the screen.
    i found if use software build tools , a *.map file can be generated . this file can also display the address map.:)
    I am wondering if there is other way (than the Nios Shell command) to find such file.
    thanks
    if you are using software build tools design flow, you can find a summary.html in the bsp file folder, it includes the hardware memory assignment. And you can also find a *.map or*.objdump file in the app file folder , it includes the memory assign of the application.
    I am using the Nios II IDE (v9.0). I can't find such file with the specified extensions neither in the workspace nor in the software folder!
    i met the same problems as you, so i have to use the software build tools design flow rather than the ide flow.
    Go to Window > Preferences > Nios II (may not be entirely correct, but you get the point...) and you'll find an option to enable its generation.
    Do you mean to generate the objdump file? the *.elf.objdump file generated contains a so mixed and confusing information including the assembly code!
