17 years agohow can i get the memory map file.
in a design , using several memory, flash , ddr, and ssram , after enter into the nios2 to setup a project, after building the project, i want to know each section 's address. but i can not find the ...
17 years agoi met the same problems as you, so i have to use the software build tools design flow rather than the ide flow.
