17 years agohow can i get the memory map file.
in a design , using several memory, flash , ddr, and ssram , after enter into the nios2 to setup a project, after building the project, i want to know each section 's address. but i can not find the ...
17 years agothanks , i have tried and the address map displayed on the screen.
i found if use software build tools , a *.map file can be generated . this file can also display the address map.:)
