17 years agohow can i get the memory map file.
in a design , using several memory, flash , ddr, and ssram , after enter into the nios2 to setup a project, after building the project, i want to know each section 's address. but i can not find the ...
17 years agoYou can either find it in the HTML datasheet generated by SOPC builder (in the same folder than the PTF file) or in the IDE itself, in a header file. Go in the syslib -> Debug -> system_description -> system.h
