21 years ago
Help with Flash Programmer on custom board
Hi!
I've made a board with cpld and flash as in Cyclone Development Kit, but different is
cpld EPM3128A only. I ran it on Quartus 4.0 (SP1) and NIOS 1.0 (SP1) and
it is configuring and working OK. I try to configure it in new version of Quartus 4.2 with SP1 single
and NIOS 2 1.1, but when I was programming it by Flash Programmer appear errors.
I've changed a JTAG_UART in custom board design and added a reset_delay block but
error is the same.
Maybe someone had this problem before?
Error:
# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd C:/altera/qdesigns42/CamelotProject1/software/CamelotProject1/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U5 --offset=0x00700000 --input=C:/altera/q
designs42/CamelotProject1/CamelotProject1.sof --output=CamelotProject1.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert C:/altera/qdesigns42/CamelotPro
ject1/CamelotProject1.sof CamelotProject1.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Thu Mar 24 13:18:37 2005
Info: Elapsed time: 00:00:00
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=CamelotProject1.flash --sof=$
SOPC_KIT_NIOS2/components/Camelot_Custom_Board/system/Camelot_Custom_Board.sof -
-cable='USB-Blaster [USB-0]' --base=0x00800000
24.03.2005 13:18:39 - (INFO) nios2-flash-programmer: Launching Quartus Programme
r to download:
C:/altera/kits/nios2/components/Camelot_Custom_Board/system/Camelot_Custom_
Board.sof
Send (64) failed.
Unable to synchronize with target.
24.03.2005 13:19:19 - (SEVERE) nios2-flash-programmer: Error opening target hard
ware
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x00000000 --end=0x800000 --rese
t=0x0 --input=CamelotProject1.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NI
OS2/components/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__NO_
SOF_PLEASE__ --cable='USB-Blaster [USB-0]' --base=0x00800000
24.03.2005 13:19:20 - (INFO) nios2-flash-programmer: SOF-download skipped.
Send (8) failed.
24.03.2005 13:19:51 - (SEVERE) nios2-flash-programmer: Error opening target hard
ware
lt
sh
design.
- exiting.
    --- Quote Start ---
    originally posted by camelot@Mar 24 2005, 01:31 PM
    hi!
    i've made a board with cpld and flash as in cyclone development kit, but different is
    cpld epm3128a only. i ran it on quartus 4.0 (sp1) and nios 1.0 (sp1) and
    it is configuring and working ok. i try to configure it in new version of quartus 4.2 with sp1 single
    and nios 2 1.1, but when i was programming it by flash programmer appear errors.
    i've changed a jtag_uart in custom board design and added a reset_delay block but
    error is the same.
    maybe someone had this problem before?
    thanks.
    error:
    # ! /bin/sh# # this file was automatically generated by the nios ii ide flash programmer.# # it will be overwritten when the flash programmer options change.#
    cd c:/altera/qdesigns42/camelotproject1/software/camelotproject1/debug
    # creating .flash file for the fpga configuration
    $sopc_kit_nios2/bin/sof2flash --flash=u5 --offset=0x00700000 --input=c:/altera/q
    designs42/camelotproject1/camelotproject1.sof --output=camelotproject1.flash
    info: *******************************************************************
    info: running quartus ii convert_programming_file
    info: command: quartus_cpf --no_banner --convert c:/altera/qdesigns42/camelotpro
    ject1/camelotproject1.sof camelotproject1.rbf
    info: quartus ii convert_programming_file was successful. 0 errors, 0 warnings
    info: processing ended: thu mar 24 13:18:37 2005
    info: elapsed time: 00:00:00
    # programming flash with the fpga configuration
    $sopc_kit_nios2/bin/nios2-flash-programmer --input=camelotproject1.flash --sof=$
    sopc_kit_nios2/components/camelot_custom_board/system/camelot_custom_board.sof -
    -cable='usb-blaster [usb-0]' --base=0x00800000
    24.03.2005 13:18:39 - (info) nios2-flash-programmer: launching quartus programme
    r to download:
    c:/altera/kits/nios2/components/camelot_custom_board/system/camelot_custom_
    board.sof
    send (64) failed.
    unable to synchronize with target.
    24.03.2005 13:19:19 - (severe) nios2-flash-programmer: error opening target hard
    ware
    in order to program flash, you must first create a purpose-built
    flash-programming design (i.e. fpga configuration) and associate it with
    your particular board. the nios development kit is delivered with purpose-bui
    lt
    flash-programming designs pre-built for several development boards. if you wi
    sh
    design.
    the process of creating a flash-programming design for your board is mostly
    automated. from a bash-shell, execute this script:
    the help-message includes references to other documentation on programming
    flash and targeting nios systems to custom board designs.
    - exiting.
    # creating .flash file for the project
    $sopc_kit_nios2/bin/elf2flash --flash=u5 --base=0x00000000 --end=0x800000 --rese
    t=0x0 --input=camelotproject1.elf --output=cfi_flash_0.flash --boot=$sopc_kit_ni
    os2/components/altera_nios2/boot_loader_cfi.srec
    # programming flash with the project
    $sopc_kit_nios2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__no_
    sof_please__ --cable='usb-blaster [usb-0]' --base=0x00800000
    24.03.2005 13:19:20 - (info) nios2-flash-programmer: sof-download skipped.
    send (8) failed.
    24.03.2005 13:19:51 - (severe) nios2-flash-programmer: error opening target hard
    ware
    lt
    sh
    design.
    - exiting.
    --- Quote End ---
    NIOS 1.1 bug?
    I have also problems with the ide flash programmer and i decided to use
    the NIOS SDK SHELL and shell scripts for programming.
    in your example, perhaps there is missing the
    --devive=<device number> part in the call to nios2-flash-programmer
    try to write your own script to program the flash,
    e.g edit
    # ################################################################################ script to flash a file
    # FILE TO FLASH
    FLASH_FILE=$1
    # PATH TO FLASH PROGRAMMER BOARD FILE
    BOARD_CONF_FILE=BOARD_1DVI02_EP1C6.sof
    # CABLE
    CABLE="USB-Blaster [USB-0]"# NO OF DEVICE in JTAG_CHAIN
    JTAG_DEVICE=2# BASEADDRESS OF FLASH IN FLASHPROGRAMMERDESIGN (!!! not in APPLICATIONDESIGN)
    FP_BASEFLASH=0x00800000
    echo ----------------------------------------------------------------------------
    echo "PROGRAM FILE : "$FLASH_FILE
    echo "BOARD FILE : "$BOARD_CONF_FILE
    echo "CABLE : "$CABLE
    echo "JTAG-DEVICE : "$JTAG_DEVICE
    echo "FLASHPRG BASE ADD : "$FP_BASEFLASH
    nios2-flash-programmer --input=$FLASH_FILE --sof=$BOARD_CONF_FILE --device=$JTAG_DEVICE --cable=$CABLE --base=$FP_BASEFLASH
    if [ $? != 0 ]
    then
    echo "--- !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! ---"
    exit 1
    fi
    echo "### SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS # ##"
    exit 0
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    # script to flash a file[/b]
    --- Quote End ---
    Where is the file?
    And the error says
    --- Quote Start ---
    Unable to synchronize with target.[/b]
    --- Quote End ---
    Maybe It is the problem that set the inapposite parameters of the common flash interface.
    Altera says nothing about how to set the parameters. I read the flash datasheet, want to find something about setup/hold/wait time with the Avalon interface, but get nothing.
    Can anybody give some index?
    Hi LiangYi,
    the file is given by the command line to the script (Command line parameter $1),
    you have to call this script in the bash shell (NiosII SDK Shell) )with e.g.
    "sh flash CamelotProject1.flash"
    I added a device number and cable in .sh file, but error the same.
    Maybe someone from NIOS developers knows what I should do in this
    situation.
    Thx.
    To Camelot,
    First, have you tested your memory with memtest project? If tested successfully, I think it is the problem of your Flash Programming Design.
    You should deal with the clk and reset_n pins(in your Flash Programming Design) the same to your real design.
    I do this and success.
    In NIOS 2 1.0 my board works, programmes and configures correctly, from this I think it is bug in new
    release of NIOS 2. My question is what I can do to remove this bug?
    But I use the latest version, it success.
    My SW is Nios II 1.1 Eval + Quartus II 4.2 SP1.
    HW is Microtronix Cyclone Dev Board.
    I mean that if Clk Pin in your Flash Programming Design is assigned to the right Pin in your real design and use the same Pll or reset delay circuit.
    On my 1C20 Development kit it works too. But not in my board.
