21 years agoHelp with Flash Programmer on custom board
Hi! I've made a board with cpld and flash as in Cyclone Development Kit, but different is cpld EPM3128A only. I ran it on Quartus 4.0 (SP1) and NIOS 1.0 (SP1) and it is configuring and ...
21 years agoTo Camelot,
First, have you tested your memory with memtest project? If tested successfully, I think it is the problem of your Flash Programming Design. You should deal with the clk and reset_n pins(in your Flash Programming Design) the same to your real design. I do this and success.
