21 years agoHelp with Flash Programmer on custom board
Hi! I've made a board with cpld and flash as in Cyclone Development Kit, but different is cpld EPM3128A only. I ran it on Quartus 4.0 (SP1) and NIOS 1.0 (SP1) and it is configuring and ...
21 years agoI have also problems with the ide flash programmer and i decided to use
the NIOS SDK SHELL and shell scripts for programming. in your example, perhaps there is missing the --devive=<device number> part in the call to nios2-flash-programmer try to write your own script to program the flash, e.g edit # ################################################################################ script to flash a file # FILE TO FLASH FLASH_FILE=$1 # PATH TO FLASH PROGRAMMER BOARD FILE BOARD_CONF_FILE=BOARD_1DVI02_EP1C6.sof # CABLE CABLE="USB-Blaster [USB-0]"# NO OF DEVICE in JTAG_CHAIN JTAG_DEVICE=2# BASEADDRESS OF FLASH IN FLASHPROGRAMMERDESIGN (!!! not in APPLICATIONDESIGN) FP_BASEFLASH=0x00800000 # #################### echo ---------------------------------------------------------------------------- echo "PROGRAM FILE : "$FLASH_FILE echo "BOARD FILE : "$BOARD_CONF_FILE echo "CABLE : "$CABLE echo "JTAG-DEVICE : "$JTAG_DEVICE echo "FLASHPRG BASE ADD : "$FP_BASEFLASH echo ---------------------------------------------------------------------------- nios2-flash-programmer --input=$FLASH_FILE --sof=$BOARD_CONF_FILE --device=$JTAG_DEVICE --cable=$CABLE --base=$FP_BASEFLASH if [ $? != 0 ] then echo "--- !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! !!! ERROR !!! ---" exit 1 fi echo "### SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS# ## SUCCESS # ##" exit 0
