20 years agohardware run problem
I am running a modified version of the microtronix loopback example on the cyclone ep1c20
When i try to run the loopback program on the hardware i get this error: There are no Nios II CPUs with debug modules available which match the values specified. Please check that your PLD is correctly configured, downloading a new SOF file if necessary. What is causing this error??java script:emoticon(':(') smilie Winnie6 Replies
Winnie,
My 2Cents. Sometimes you get this error if the CPU you selected in SOPC does not include a a debugger.( Use atleast Level 1 in the JTAG debug module port). -Baycool - Altera_Forum
I check my cpu settings in the SOPC and level 1 JTAG debug module is selected.
what other settings and/or code can cause this problem?? PLEASE HELP http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif Winnie - Altera_Forum
Are you sure that you're downloading the right SOF file (hardware configuration) before attempting to debug the design? If you're not, then you'll see the problem you have described.
Funny thing is
It works on the wrong SOF file. When I download the kitchensink.sof, which has a lot of other additional components that are not being used, it works. But when i download the SOF for the hardware configuration, it doesn't work. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif HELP http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wacko.gif Winnie - Altera_Forum
That's really bizarre...
In the Nios II IDE, did you create the following for the new project (not the kitchensink one): * Library * Application * Debug Session ? Or, are you using the old software project settings with your new system? - Altera_Forum
I took the old loopback project, from microtronix, which was running Nios II with legacy SDK support, and updated to run with HAL
In SOPC, I did the following: *removed the rom and increase the on-board ram size. *added a JTAG UART *change the CPU setting to include a lv. 1 debug module *disabled the legacy SDK support In Nios II IDE, I did the following: *start a new project (C++ application with a new system library) *modified the original loopback.c code (change the headers, replace API calls with HAL and ANSI C calls, changed register access to use HAL I/O Macros, etc.) Did I miss something?? Winnie
