20 years agohardware run problem
I am running a modified version of the microtronix loopback example on the cyclone ep1c20 When i try to run the loopback program on the hardware i get this error: There are no Nios II CPUs w...
20 years agoThat's really bizarre...
In the Nios II IDE, did you create the following for the new project (not the kitchensink one): * Library * Application * Debug Session ? Or, are you using the old software project settings with your new system?
