20 years agohardware run problem
I am running a modified version of the microtronix loopback example on the cyclone ep1c20 When i try to run the loopback program on the hardware i get this error: There are no Nios II CPUs w...
20 years agoI took the old loopback project, from microtronix, which was running Nios II with legacy SDK support, and updated to run with HAL
In SOPC, I did the following: *removed the rom and increase the on-board ram size. *added a JTAG UART *change the CPU setting to include a lv. 1 debug module *disabled the legacy SDK support In Nios II IDE, I did the following: *start a new project (C++ application with a new system library) *modified the original loopback.c code (change the headers, replace API calls with HAL and ANSI C calls, changed register access to use HAL I/O Macros, etc.) Did I miss something?? Winnie
