20 years agohardware run problem
I am running a modified version of the microtronix loopback example on the cyclone ep1c20 When i try to run the loopback program on the hardware i get this error: There are no Nios II CPUs w...
20 years agoAre you sure that you're downloading the right SOF file (hardware configuration) before attempting to debug the design? If you're not, then you'll see the problem you have described.
