20 years agoFail in run as "Nios II hardware"
I am using Quartus II 4.2 and Nios II Development kit 1.1. After programming the standard processor, I try to run the C/C++ project into the board. I always obtain the following error: "using cable "byteblastermv [lpt1]", device 1, instance 0x00pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused" Note: I restarted the board many times and always getting the same error. My best regards, Julia
What board and hardware design are you using?
--- Quote Start --- originally posted by julia@Jun 12 2006, 06:45 PM hello,i am using quartus ii 4.2 and nios ii development kit 1.1. after programming the standard processor, i try to run the c/c++ project into the board. i always obtain the following error:
"Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused[/b]" Note: I restarted the board many times and always getting the same error. My best regards, Julia <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16136) --- Quote End --- [/b] --- Quote End ---
Hi Chris,
I am using Cyclone EP1C20F400C7 device, and a C/C++ application I implemented. Thanks in advance, Julia. - Altera_Forum
The JTAG has very poor noise immunity and can easily suffer double-triggering.
Make sure all cables are as short as possible. Alternatively put schmitt buffers on your board for the JTAG signals to avoid double-triggering. - Altera_Forum
Typically I get that message when I have incorrectly assigned my pins and the system is not functioning properly as a result. Are you basing the hardware design off of one of the example designs in the kit or something you have created manually?
I assigned all the pins and I am trying now with the hello world application. It works for sometime and then suddenly it stops working and give me again error: "Pausing target processor: not responding." or "Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x021208B8: does not match ID value does not match: read 0xC34A4322; expected 0xC64D2E14 Timestamp value does not match: image on board is older than expected Read timestamp 15:23:42 2006/06/22; expected 18:22:19 2006/06/22 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor" Thanks, Julia.
